Need a stock file for 5.9, Here is the vin #
3D7KS28C66G117251
Thanks!
3D7KS28C66G117251
Thanks!
Bump
Well does anyone know where I can get one since 4shared doesn't have em anymore
What OS are you looking for?
Whatever OS there is for that vin. I can't pull the tune from truck to see.
You can query the ECU to see what OS it's running via the V2.
Automatic or manual? Can't tell anything about the OS from the vin.
It's a automatic, crew cab 4x4, shifter on the floor.
Full set of Cummins and Duramax Stock Tune Files
https://forum.efilive.com/showthread...ax-Stock-Files
Thank you
FYI -
Controller VIN, OS, Serial number, and for Cummins controllers Calibration ID can now be displayed on FlashScan and AutoCal screens. Users can access this information by connecting their EFILive hardware to their vehicle, and following the below instructions:
FlashScan: F3: Diagnostics -> F1: Display Info -> F1: Display VIN/Info.
AutoCal*: Users can navigate through to the following menus
•Scan Tool->Display VIN
•Scan Tool->Display OS
•Scan Tool->Display SN S
•can Tool->Display Cal ID (for Cummins controllers only)
* Advanced menu only. You may temporarily activate the Advanced menu by holding down the [Next] button while powering up AutoCal. The Simple menu will revert when the device is next powered up.
Ok. Main reason I'm
Looking for the correct OS is because airbag, parking brake, and ABS light is on and has been on since last tunes where put on the truck.
IIRC if you forget a value or get a letter wrong it'll start but have dash lights...or something to that effect.
At this point verify the correct Vin is flashed into the ecm, and if the lights stay on then you'll need a dealer tool to reprogram the tipm and abs module with the correct Vin.
Okay thank you, I'll see what I can do.
