You need to contact Guy at Socal...it's a known issue and a replacement cable will be issued
Thanks Les! Will do.
Hey Les, my switch stops working regularly when data logging with my v2 connected to my csp5 pass thru switch. Do you think this a similar issue the cst is experiencing?
Doug
Are you trying to change tunes with the switch while logging?
Yes. That is when it has issues and I need to unplug to reset it.
I'm not sure if there is a solution for that, other than resetting it. I learned in the beginning that your issue is gonna happen when you have two devices trying to do the same thing on the same network.
I unplug my switch when logging then plug it back in when completed
Thanks Les,
That's what I figured. It's not a big deal, just figured I would ask about it.
Doug
The only issue I had with flashing though the CSP5 switch was when I had a single tune in the truck and was trying to flash a csp5 tune into the truck.
I always have unplugged them when flashing trucks.
