Re: Update: June 06, 2013
Anyone?
Quote:
Originally Posted by
Cougar281
Has anyone else had problems with the V2 corrupting SD cards? So far it has happened to me twice. Once with a 512MB card and the second time with a brand new 4GB card. The V2 will be happily logging, then I'll hear it beep, I look at it and it says saving {filename}.efi, then if I try logging again, I get file or folder not found. When I read it in a PC, there is no good data on it. I'm running the latest public release.
trouble reading and flashing with v7.5
I have trouble reading LMM TCM's with this release in v7.5. I cant read, cal, or full flash a LLY ECM with V7.5 either. I also get a message that the LLY controller is locked when I try to scan the ECM so I can lock it. I can read it and write to it with V8 fine, but it says its locked in v7.5.:throw:
