B3701 Injector pulse width voltage adjustment
Injector Offset vs. Volts vs. Vacuum on my excel spreadsheet with Injector Flow Rates:
is this the same as B3701 Injector pulse width voltage adjustment?
If so, it's 90*s out with kPa at the top instead of vertical. The vertical on the spread sheet appears to be the volts 4.5 to 20.5 the horizontal at the top is -80 to 80
There are three of these charts, #2 goes from 20 to 180 and #3, the range is 128 to 640. It only has the above title and no lables.
Any one knowledgeable about this and could you please enlighten me.
Also, I tried to attach this spread sheet to this message with manage attachments and I flunked the test. Again!
I thought this spread sheet with ten different injector flow rates and all associated information would be of use to others.
Thanks, Curt
