PID not supported?
Trying to do some logging on my newly tuned 2017 Camaro SS. Well I say tuned but it's just setup for E85 and now I want to get into tweaking it. Most of the tables like spark advance and other go off of RPM and Air per cylinder grams/cyl. But when i select the pid for air per cylinder it says not supported and won't even open up scan. How can I scan this stuff if the pid is not supported?
Nobody know how to log airmass per cylinder or why this pid isnt supported?
The PID would be a DMA PID I think, meaning the ECM does not support it from GM and it needs to be added in (well, worked out) per OS for EFILive to be able to log it.
I do recall someone posted here a way to log it using standard PID's but by doing it via a calculated PID.
Thats what i was afraid of that, so Complicated
1 Attachment(s)
I dug thru my old old archives, l found this (attached)... look thru it and choose what you need.
