joecar, I'm using a female to female serial adapter I got from radioshack. no analog signals are being used.
mr.prick, I'm pretty sure the WB is hooked up correctly. I had a hell of a time getting the LC1 setup and operating the way it should but I'm sure its set to gas 14.7afr. I might try another recalibration ( I only did about half a dozen so far) to be sure the HUGE a/f swings aren't a miscalibrated sensor. it does hover around 14.7 a few minutes at startup and while I'm crusing but its not nearly as steady of a reading as my LM1 is.
Use "serial" with the V2 , LC-1 combo , the LC-1 1.10v firmware is flaky in analog form .
Hmmm , like joecar says in a CO3 the O2s are only active if you have a semi-open loop mode enabled .
No DTCs ?
^^ how would I know if semi-open loop mode enabled... can't that be figured out by looking at the log, it doesn't appear that the o2 voltages move that much.
^ that pic looks exactly like the adapter I have... except I don't know if it says null modem on it, I don't think it does. So I guess that means I've got the wrong adapter, bummer. I'm going to order the one from the link you posted right now, THANK YOU!
will this one work? It says null modem adapter but I think its male on one side and female on the other... not 100%
http://www.radioshack.com/product/in...&tab=techSpecs
sorry for all the questions.
See how the null modem adapter crosses pins 2 and 3...
http://usera.ImageCave.com/joecar/LC...can-Serial.png
I'm an idiot sometimes... thanks for the HUGE pic
Get the LC-1 cable form TAQuickness , direct connect .
