Known issues with the September 2015 Public Pre-Release
Currently known issues and possible workarounds for the September, 2015 Public Pre-Release of the EFILive Software and Firmware
Download the current/stable release software here: http://www.efilive.com/latest/cat/download-efilive
Download the public pre-release software here: https://forum.efilive.com/showthread...ic-Pre-Release
Public pre-release software versions:
- Software: V7.5.7.293
- Software: V8.2.2.286
- FlashScan/AutoCal firmware: V2.07.91
Issue 1:
Workaround:
None.
It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
Issue 2:
DMA PID links defined in E40_Link.ini are incorrect.
DMA PID links defined in E92_Link.ini are incorrect.
Workaround:
See this post: https://forum.efilive.com/showthread...l=1#post222648.
