LML BBL PIDs corrections
Did some LML BBL this past week and found a few errors in some of the PIDs set up for V8.
Here’s a list of LML BBL PIDs that the Description or Unit are not correct for BBL when using EFILive Scan and Tune when compaired to the LML_PIDs.txt file.
Any chance of the getting them corrected in the LML_R.obj file that feeds the available PIDs for the LML and a updated file posted?
TCOS, [2] Transfer Case Output Speed (RPM)
DPFPRV, [2] DPF Pressure Variance (kPa)
WIFV, [1] Water In Fuel Sensor Voltage (V)
DPFSV , [1] DPF Pressure Sensor Voltage (V)
FUDPFR, [2] Fuel Used Since Last DPF Regen (l)
DSTDPFR , [2] Distance Since Last DPF Regen (km)
EGT2A , [2] Exhaust Gas Temperature Sensor 2 (°C)
EGT1A , [2] Exhaust Gas Temperature Sensor 1 (°C)
DPFRGENC, [2] DPF Regens Completed (Count)
DPFSOOT, [2] DPF Soot Mass (gms)
TCDBP, [2] Desired Turbocharger Boost Pressure (%)
