My EfiLive V2 installation CD didn't come with Cos#5. Where do I download this?
See post #218: showthread.php?t=2599&page=22
Those are currently the latest files for COS5.
Joe, thanks for the link.
I'm having a little trouble getting the my 2000 T/A to run. The first thing I did was to upgrade and reflash the 2000 operating system to a stock 2002 version. After I did this I fooled with the "idling" tables to get the car to run (this was a partial success) and eventually I came across a tune located on HoldenCrazy.com which was a '99 migrated to '02 tune. Here are the descriptions and link:
1999 Camaro Coupe 5.7 Litre Manual LS1 PCM 12212156 484,542 Bytes Stock Tune Migrated To 2002 Operating System
http://www.holdencrazy.com/EFILive/T...t/00000020.tun
So I reflashed this new calibration and the car would idle great. Following the COS tutorial, I full-flashed COS#5 then flashed the working calibration file. After I did this I went through the out-of-bounds tables and adjusted them according to the tutorial. Well, needless to say, the car will start and about 3 seconds later will die. Is this a typical problem? I'm very new to tuning of any kind so any insight would be greatly appreciated.
Do you have the "TPS vs RPM" VE table disabled...?
Quote:
Originally Posted by joecar
Thanks, that fixed it. I didn't miss that in the COS Tutorial did I? Perhaps that step should be added. Now I'm getting somewhere using the RAFID process and I'm starting to have some fun. :)
It's buried deep inside the COS5 thread: showthread.php?t=2599
It really needs to be collected and organized into the COS tutorial pdf.
