Known issues with March 2015, Release Candidate 1
Currently known issues and possible workarounds for the March 2015, Release Candidate 1 of the EFILive Software and Firmware
- Software: V7.5.7.280
- Software: V8.2.2.274
- FlashScan/AutoCal firmware: V2.07.81
Issue 1:
Workaround:
None. It is a restriction of the *.efi (V7.5 log file format). That restriction will be removed and the TCM PIDs will display their true origin once the V8 scan tool software is available.
