i just try that,
but the same Issues .
The regional settings being set to a non English local is the only known way of getting that error to occur. Similarly, setting regional settings to English (United State) has worked in all other cases. Please do double check that you correctly made the recommended adjustment.
hi all, may I get advice to updatemy v8. I seem to need build 191. anyone have it so I may catch this thing up.Thre only version I see is Download is ---- EFILive V8.2.1 Build 203... it will not update I get a 403 error? or something.. Thanks, Caleb
HI Thank you for your time and reply Joecar I (cant get the pic.. )now I have v 8 installed , and 7.5 , both the latest.. Upon hooking cord & V2 I am getting blue screen on v2 scanner.. tried loading usb manager... IT loads, and I get options to install either 2.02.04 or 2.08.14 . (I am in admin mode..) I get error code 740: the request operation requires elevation. NOW What Please Anyone
See post #24 here: brand-new-V2-crashes-my-HP
Requiring elevation: your admin login does not have high enough privileges.
hi joecar the only guy on the computer is me and if i rt click i have all options checked for privileges in acct. how can I fix ? ??
The 740 error is related to UAC. See THIS knowledgebase article
rebooted .. updated, this time all good.. (reboot x3 then admin wt heck)... 3rd try a charm thanks..
