Hey all, how can we soften the timing retard on full throttle downshift without adjusting minimum timing?
this only seems to happen when in top gear, plant your foot, the car hits a brick wall downshifts then comes alive.!!
I have the same problem.
I started looking at T43 now, and after I m going to do tests.
Problems...
Without any modification in T43, just speedometer and rpm limiter, this problem remains!
Is engine exceeding any engine sanity table...?
Post files.
torque management strategy , did you screw with the torque tables ??
I did modify the torque tables, with or without modification it still retards.
Have a play with these Attachment 18072
I found by disabling the Torque Management on upshift.... made the transmission perform poorly, however I'm curious to know how you control how much spark is retarded on the upshift??
Any movement on this?
I wouldn’t fully shut off the TQ management. Just reduce it.
Tuning the trans shift behavior is in the ECU
Post up your file. You probably have some nannies still turned on in the ECU.
