LMM tune makes no difference to power
My LMM conversion is at the tuner. He is saying no matter what he changes no difference in power output whatsoever. The tune flashes fine with no errors.
I am wracking my brain to think what could be the problem. He is an experienced tuner but favours HP over efilive, however i have requested efiive for the dsp5.
I pulled the tune with 7.5 and deleted some codes that are irrelecant for a retrofit, reflashed many times with no issue, vehicle drive great. I then converted to dsp5, installed the switch, flashed that and sent it to the tuner along with a copy of the file (as he cant pull the dps5 himself).
He is trying to tune it with 8 on my 7.5 file as his starting point, could this be a problem?
I suggested he reflash the non dsp5 file with 7.5. Re read it with 8 and go form there, or should he be using 7.5?
Assistance greatly appreciated as i am on the clock here
