1 Attachment(s)
Needing Factory File
Hi just chasing a factory file for a HSV VE GTS 2007 LS2 24239353 op system and 24239647 cal. If anyone has one it would be greatly thanked as i haven't been tuning long and this file is pretty horrible to drive and don't want to start with it. Attached file just incase more detail is needed.
Are you chasing Engine or trans calibration, as that is a trans calibration you have posted.
After the factory trans file
1 Attachment(s)
Not from a HSV but same OS and calibration.
Not sure if that will work in a VE commodore as the corvettes use active select (manual changing) differently to a Commodore
