Interesting idle ? I could not find anywhere
I've noticed that when I first start the car on cold start it idles low and rough. Ok, figure this is a problem in the idle section and can address it later. After it starts to warm up it 's good at 950-1000rpm and EQ stays at 1.0 almost constantly.
I then realized that it does the same after a hot restart so I decided to log the hot restart. Seems the PCM is commanding 12.96 AFR for about the first 2 minutes where as the car idles around 400-600 and almost shuts off. At the initial fire up actual AF is 17 for about 10 seconds then it falls to the 12-13 range for this first 2 minutes or so.
Why would it command 12.96 breifly even on a hot refire and what would need to be adjusted?
Thanks in advance
Shawn
