The description for {B3321} Skip Shift Min Throttle says:Throttle position percentage above which CAGS "skip shift" will be allowed.It probably should read "below which" ...
This was E38, OS 12614676.
This might be another in B1906;
RonQuote:
Once the knock conditions are no longer present the ECM will being to ramp the knock timing retard back to normal run spark timing at a rate defined by this table.
