LM-1 Programming & Settings
What are accurate settings for analog outputs 1 & 2 on the LM-1 to work with V1 on V7.5? My current seetings are:
Analog Output One:
.996v @ 10.01AFR
4.996v @ 19.99AFR
Analog Output Two:
.996v @ 10.01AFR
1.998v @ 19.99
My logged AFR results come in leaner than the reading on the meter. I've searched and read a lot of threads but there are varying proposals for getting the programming right.
In the past when working V7.3.3 I made some mods to the sae-generic.txt. However, those settings skew the results way rich with my current setup. The only change I currently have to the sae-generic.txt file is maximum AFR at 20 rather than 30. If any edits ought be made there, let me know.
Thanks for any help!
