Oh, I forgot that you might be logging wideband via AC pressure sensor or EGR position sensor...
if this is so then we can create a wideband AFR/lambda pid using the EGR voltage...
you might have to enable EGR in the tunefile.
That sounds great Joecar. That would seal the deal with my setup. This is on my wifes 05 4.8LTahoe. i'd like to add to the thread for everyone. Ill post a log soon. Even a scan only V1 would be deluxe!
I made the suggested changes Joecar. My "units" look off by quite a bit. The VE table values are very low; seeing 55 should be 125. Also, the MAF table has some larger than anticipated adjustments at 2750Mhz. I do have B0120 set around 3500RPM and my B3616 and B3618 are still in street trim. WO2LAM1 is also invalid. How do I get around this with my setup? THANKS for all the help guys!!
Hi Josh,
Since you don't have a wideband, you will need to use LTFTBEN for correcting the MAF table and calculating the VE table...
use the attached calc_pids.txt file...
( you will only be able to tune Closed Loop, you will then have to extrapolate the delta to the other regions of MAF and VE until you get a wideband )
Make sure your OS supports the pid GM.DYNAIRTMP_DMA... if not, let me know and I'll modify your calc_pid.txt.
WO2LAM1 is only valid if you have a wideband connected to FlashScan V2 using a serial comms cable.
Set B3618 to something like EQR 1.175 all across, and set B3616 to something like 2002 Camaro (65% TP below 3200 rpm, 35% TP above 3200 rpm).
You can leave B0120 as is (because with the Calc.VET procedure, the transient filter happens to filter out VE contribution).
Giving it a shot now. Thanks Joecar! If I go the Ac pressure route, I'll take the help on setting it up.
Should I have the SELBEN in the new calc.pid without the
*CLC-00-220 factor 0.5 1.5 .4 "iff({CALC.CL}, {CALC.LTFTBEN}, ""{CALC.WO2BEN})""
CALC.WO2BEN entry? If not, just use the BEN from LTFT for my MAF table?
Using the BEN from LTFT for the MAF gives sane values. I hooked up my LM-1 again! I am currently messing with the NB simulation output. I have a harness in the car that I ran a couple years ago. The car runs fine (CL) with my current settings and shows .85-.87 lambda when in PE. I need to run the 5v signal to the AC or EGR now.
