Anyone have a Stock file for OS 11720604... Calibration ID 72350435AQ
2007 Ram 2500 Federal Automatic 4x4
Downloaded Tune attached was returned to stock from a box tuner that I want to rule out as the issue
Thank You
Thank You
Closest I have is a 72351435BH, so I couldn’t do a compare to see if there was anything funky in your read out file. I can post up the 72351435BH if you want to try using that.
So a PSA for people wanting to use wiTECH 2.0
Your 2534 pass through, needs a minimum of 3 CAN channels. My GM MDI and Nexiq usb do not...
I have a Controller Technologies Corp. Pulsar on the way
Supports 4 CAN, Lin Bus, ETC...
Here is the file that was Generated from Mopar TSP for this Truck if it might help someone.
The OS changed. I'm not sure what to think about that.
The Calibration ID stayed the same, except for the updated letters at the end
