1 Attachment(s)
E98 - Injection Timing Calculator
As Arnie always says, it’s good to give back to the community.
This is an Injection Timing Calculator for the E98 ECM OS:55499969
It works with my OS, however I'm sure with other OS's their tables are using the same X & Y Axis values etc.
It's used to calculate your optimal injection timing for EFI Live tunes.
Most people just use a single number for overall injection % BTDC, however more advanced users use a blend of 40%/60% for best results which is later on down in the spreadsheet.
Do not use the HPT injection pulse values as they are double of what’s on EFI Live, which are correct as I've had this verified by them.
Thank you Ross / Cindy for the help.
Cheers :mrgreen:
Attachment 23572
