I have done the procedure a few times and it still displays the same start up temp.
This is on a 2007 z06.
I am wondering if it has anything to do that the car was ls2edited.
Have you tried reflashing with a stock tune file (full flash if you can, cant remember if we can yet on E38s) then applying the patch?
Fan patch has not worked correctly since build 64
How can I make them start correctly?? installing a lower build?
I did a car today and found the following.
Follow the normal process to aaply the patch.
Then open G0901. The first vaue is still 89'C, but it repesents a value about 9'C lower.
If you want to activate the fans at 90'C, then change the % in the 99'C.
You might have to play with values to get the desired values.
oohh.. Interesting.. will do that tomorrow when the car comes in.
Confirmed.. its working...
Labels do appear incorrect for me.
yes.. but they are working correctly as said above
