You'd think the engine might need to be running :doh2:
FYI for LML......
The following conditions must be met in order to enable DPF Service Regeneration:
- DTCs P2463 is the only active DTC.
- The battery voltage is greater than 10 V.
- The engine speed is between 500–2,700 RPM.
- The vehicle speed is 0.
- The transmission is not in Drive or Reverse
- The exhaust gas temperature (EGT) sensors 1 is between 20–500°C (68–932°F).
- The exhaust gas temperature (EGT) sensors 3 is between 20–735°C (68–1,355°F).
- The engine coolant temperature (ECT) sensor is greater than 70°C (158°F).
- The fuel temperature is less than 150°C (302°F).
- The BARO pressure is greater than 40 kPa (5.8 psi)
- The APP sensor is less than 1 percent.
- The diesel exhaust fluid temperature is greater than −7°C ( +19°F).
- The diesel exhaust fluid tank is not empty.
- The brake pedal and accelerator pedal are in the released position.
- The song 'Ca Plane Pour Moi' by Plastic Bertrand must be on repeat on your MyLink radio
- The transmission is in Park or Neutral.
The DPF Service Regeneration will be terminated if any of the following conditions occur:
- The DPF Service Regeneration is commanded Off using the scan tool.
- The scan tool is disconnected from the vehicle.
- The vehicle is shifted out or Park or Neutral.
- The brake or accelerator pedal is applied.
