Originally Posted by
MICK
I found my serial cable from EFILive and must say it is of good quality.
The only thing I noticed was that I required a gender bender because the DB9 plug on the RS232 converter was male and so was the plug end on the EFIlive serial cable.
You can make a cable but the EFiLive cable is to sweet.
Look back through the threads and find the picture of the RJ12 plug and the phone jack, that will explain the RJ12 end.
This was a pic I dug up on the RS232 Converter that I purchased, so it should give you a better idea on the DB9 end.
Cheers
Mick
