I'm trying to see if you can get the gauge to move at all.
So far, nothing has affected it, stays pegged. Ended up running it way too low today not paying attention and almost ended up on the side of the road. Added 15.7 gallons, oops!
Try doing the full flash again.
Did a full flash, still nada
Would I just full flash right back to the stock 02 OS, then swap in the fuel segment and do a calibration flash and see if it works? If it does then start copying over all my current tune tables?
And if it doesn't work and I want to get back to where I'm at now so the car is at least driveable, I can just full flash my current COS5 tune right back in no problem?
Save your current COS5 tune.
Then full flash to the GM tune, do the fuel segment swap, do a full flash, and see if gauge works.
If it does, do the empty COS5 full flash, read it back (do the sanity edits) and save as new file, see if gauge works.
~ posted by phone ~
Ok, just wanted to make sure! Thanks Joecar
Still didn't help unfortunately. I'm not sure how I made something so simple, so complicated! I'm wondering if the sender crapped out or the wiring is jacked up somehow
If I'm reading the electrical diagram correctly, I should be sending 5v down the purple wire to feed my sender, my multimeter is showing only 1.2v, hmmm. Does this fuel segment stuff affect the voltage being sent to the sender in any way?
