You should be able to right click and Edit Row or Column Labels.
I will bow to the experts on that one, there's probably something else in the software that affects that.
Ttt
TTT. Looking for some guidance or assistance. Thanks
Bring this back up. Still an issue and curious if it will be corrected.
Ttt
Sorry this just kept slipping under the radar, you can't fix the labels, it has been incorrectly defined in the .calz file.
Noted and will fix.
FWIW, it is just a display issue, the actual table values (as in the values in the 3D map) aren't skewed by what is shown in the axis value, the axis values are just coming from the wrong place (to fix them would be a disaster, the .calz needs to be fixed).
