At what stage do these errors occur? What steps do you perform after the software starts before the errors show up?
Some detective work you can try:
For V8, hold down the Ctrl key on the PC keyboard and double click the V8 Scan and Tune icon to start the software. That should create trace/log files in the \Documents\EFILive\V8\Trace folder. Look in those files (using Notepad) to see if you can see any reason for the errors.
For V7: Change the properties of the desk top icon so that the "Target" field has a space, forward slash, lowercase L after it, like this:
Attachment 22668
Then run the V7 software, that will create a log file in the folder: \Program Files (x86)\EFILive\V7.5 called StartupLog.txt.
You will need to right click on the desktop icon and select "Run as Administrator" otherwise V7 won't have permission to create the log file in the "Program Files (x86)" folder.
Again, check that log file for any clues as to why those errors occur.
