COS#3 ... Max MAP = 105kpa in the scanner?
I have a 2bar map and am running COS#3. I noticed today that I slipped while trying to log some 0.0psi and hit 1-2psi a few times, which should have put me up into the 115kpa cells. In the scanner, however, the ben table only showed up to 105kpa (I made my labels through 285) and the max logged in the dashboard is also 105kpa and not 113kpa. The SAE MAP pid says it loggs to 255kpa...
MY C6301 is 194.0039 which makes my baro reading match the local ambient pressure.
Am I missing something here?
