Sent !
Sent !
All three files load up fine in my version of V8 here.
What exact steps did you go through prior to getting that error?
In case it's a configuration issue, can you send me these files from your PC:
\My Documents\EFILive\V8\Config\EFILiveScanAndTune.ini
\My Documents\EFILive\V8\Config\EFILiveScanAndTuneLayo ut.ini
\My Documents\EFILive\V8\Config\UserCalculatedPids.ini
\My Documents\EFILive\V8\Dashboard\EFI_LB7_Sample_Metr ic.dsh
CMD flash times seem to have slowed way down with this update. Standard/Fast CAN/ Fast CAN unlimited all take right around 17-19 min. Previous release (build 315) is ~7-8 min with Fast CAN.
Any Update on the Update? Lol
Sam
The beta-2 update is due out this week. It's in testing at the moment. If testing goes well then it should be available in a day or two, if not then hopefully by the end of the week.
Sounds good,
Sam
Update is now available here:
https://forum.efilive.com/showthread...Beta-Release-2
