Yes i did activate both and tested every combination of those nothing works, and my slider only goes to 1,0 rpm and 1,0 mpa.
Is the problem again with the country setting like it was with scripting?
I'm also using european keyboard.
Did you select Target Controller as E54 LB7 Duramax (as shown in the pic in post #10)...?
Yes the controller selected was E54 LB7 Duramax ECM, everything else works if i try the switches tab for example i can turn my MIL lamp on and of so i guess i have the right controller selected.
My screen looks like this when the sliders are at MAX
Attachment 13441
Yes it is almost certainly a decimal point versus comma issue in floating point values. Try changing your locale settings to US and see if that fixes the problem.
I will do some testing here with a locale that uses a comma to separate decimal values to see if that is the actual problem.
Ok thats the problem i changed in win7 region settings format to english (US) and the sliders shows the correct numbers, but when i change my format to Finnish (Finland) it only shows the 1,0 value, it would be nice to have this working in my native settings.
Thanks again for the great support.
Thank you Paul for awesome customer support!
