YES, it worked well. THANKS!
any one able to fix this one for me??
its been frustrating!!!Attachment 22158
I will have a try next week, got some other things I had to do first...as putting the car back together from paint :)
I did try to open the file with the latest version of EFILive Tune 7.5.9 (build 320) and I get an error message that the file is saved with a more recent version? Is there any newer version available and what version did you use?
Thanks alot for giving it a try!!
Try this: Current-Public-Release-(May-2018)
Is this issue something we can expect to be corrected in an upcoming update? I really hope it can be.
Try this:
Attachment 22181
Well, I spoke too soon. The vehicle has been driving around the parking lot getting other parts of the build finished for a few week. The other day it got driven a little more...no shifting out of 1st gear. I went back and looked at the file (that works the fans properly) and it says its for a 6L80e. The original tune I was working with was for the t42 4L80e setup. Darn...so I guess I'm back to the drawing board.
I looked into it further, I cannot make a trans segment swap in this case, but I can make a "system" swap. Can someone enlighten me as to what that includes exactly? What would I be swapping over? Is there any chance I can just swap the system with the properly working fans into the tune with the properly working transmission? Obviously I'm going to try it anyway, I would love a little more in depth info so I can learn.
Lastcall I appreciate your help with this, its not your responsibility I know but if you would like to PM me for any reason that would be great. If not, I do appreciate you helping me with the issue up to this point.
LS-SWAPPER, try this file. I made the changes to your file from post #42. It's not segment swapped.
Attachment 22287
