Issue with running after tune instal
have an 06 and when i flash a tune into (i used the factory cal and modified it) the truck the trans geeks out and will put it in limp mode and throw an over temp code...
another issue i have seemed to encounted is a random soft limiter after doing a second tune on it...worse under load
if someone is willing and is familair i can email tunes so they can be looked at and maybe some insight if someone is willing to help or can pinpoint with some more information on my end. i'm going to do some data logging and try and figure out whats being limited...thing is it doesn't happen consistantly....
Mike
