I will have to check in the morning when I can get to the car. With the V1 just plugged into my computer, I just get the error that it is not connected (which I assume is normal).
Prior to working on the 2002 OS setup, it always displayed my correct VIN on one license and the other was available.
I will get back to you when I plug into PCM.
3 Attachment(s)
Got some screenshots of pcm info today when I was hooked up.
Still not sure how I lost my second license but here is the info.
Thank you
1 Attachment(s)
Can you show a screen shot of PCM info screen like the image attached.
I will get a screen shot of that in the morning and get it posted. I was wondering if I was getting the correct info.
Thanks,
Robert
5 Attachment(s)
Ok, hopefully this is the info that you have been trying to get out of me. lol I'm a bit slow at times.
License #2, obviously, is locked to my pcm. License #1 is the problem. I loaded a tune, from the EFI Live repository on LS1Tech about the time I noticed my open license went away. Not sure how that would happen, though.
Please let me know if you need anything else.
I can't explain why there are two used licenses on that cable. I'll send you a replacement license asap.
I noticed that your V1 is a Personal Scan and Tune. That can't be used to upgrade the OS in a PCM. To upgrade you need to do a full flash and only the Commercial version can do a full flash. So if you are planning on doing an OS upgrade you'd need to upgrade your V1 to a Commercial. (It's only $50, here: http://www.efilive.com/index.php?pag...mart&Itemid=56
Robert, did you get the Commercial upgrade ok...?
Joe,
Just about to buy it today. I did, however, get a new license to replace the one that I lost. Not real sure how it happened but the people at EFI Live helped me out. Support here is awesome.
I am baffled by one tuning question though. I will post it in my most recent thread if you would look at it.
Thanks to all for the help with my license.
