B5916 base spark closed throttle threshold vs. tps voltage
from searching and reading about idle screw adjustments a tps reset will be required, if idle screw adjusments are made.
also i assume the voltage needs to stay between .4-.6 volts. or am i not understanding?
does voltage make a differance beside making a mil if tps sensor fails?
my iac counts are maxed. i have to hold about 7% throttle to make car idle and it likes to see 36-40* to idle more so (smooth) you could say.
im trying to do all this w/o making the hole in the tb bigger, which will be the last resort if needed.
what are the limits to the tps reset?
any comments or questions will be appreciated!
thanks.
