does this happen to anyone else? it does it to lots of logs.
Are one of your number keys stuck down? Looks like it's 'marking' a point in the log.
no all keys are fineeeeeeeeeeeeeeeeee.
when i open a log, it doesnt display all the pids i know it recorded.
Check your software version, and also the firmware if you are using FlashScan V2.
Software should be at least 7.5.5 Build 88
FlashScan V2 firmware should be at least 2.06.12
This was a problem a while back...
Oh. And the PIDs should all show on the F9 Data tab (not necessarily on the graphs/gauges unless you have specifically changed them to show a different PID.
7.5.6 build 99
does anyone else have a problem looking at logs at all or is it me?
