Awesome. I'll let you know how that works. I still haven't figured out how to manually hold first gear though...:/
Thanks Joe, I was abled to get out and try the file you sent. The manual first gear does now work so thanks a bunch for that. I'm still not abled to get the converter to lock up to OD for some reason though. I also need to make a few other minor adjustments, it never ends lol....
Post a few logs of the TC trying to lock...
include the following pids:
SAE.VSS
SAE.RPM
GM.TP
GM.TFT
GM.GEAR
GM.TCCMODE
GM.TCCSLIP
GM.MFTOTAL
GM.TSTATE09
GM.TSTATE10
keep the channel count (see at bottom of PIDs or Data tabs) to 24 or less so we can get the most data.
