New Tune File Shows Up In Explorer But Will not load to Autocal
Hello.New here.I received an Autocal from a reputable tuner with a DSP5 tune.I was able to flash it into the ECM without any issue.Unfortunately,I was not able to switch tunes.My tuner sent me the same file to try again with the same negative results once again.After checking ECM plug pin locations and testing the switch it was determined that the tune file was corrupt.He emailed me the new tune but it shows up in Explorer and won't load onto the Autocal.Finally,the tuner walked me through getting the tune loaded using my laptop and Autocal as a passthrough.Problem is;the old tune (which is no good) is still on the Autocal and the new tune sitting in the Explorer program.What can I do to resolve this?I don't want to delete any critical data from the Autocal to make room for the updated tune.Thanks for any help.-Andy.
