1 Attachment(s)
Help with vehicle staying running and cold starts without throttle aid...
I cannot for the life of me, get my vehicle's tune correct so that it will start on it own without giving it gas on cold starts. It will start without help once warmed up though.
And also after a complete cold start the vehicle will not stay running after gear changes. Idles fine in park at first, then put it into reverse...after about a second it starts dropping rpms then stall saves, then dies. Restart, same thing happens again until I can give it enough gas to stay going for a while. But if it isn't warmed up enough before the next complete stop it will die again.
Then if it isn't completely warmed up but not completely cold its a 50/50 shot that it acts this way.
I've been through all the normal idle threads and tutorials and just can't get these 2 situations tuned out.
I have the right desired air flow, IAC counts, etc.
I am posting my tune below, and help would be GREATLY appreciated.
Jeremy
Current Tune:
Attachment 16668
