Starts, reduced power, and then dies...
hey guys. working on a supercharged C5 z06. I have followed the custom OS pdf file and rescaled for the larger injectors(60lb) and 2bar map sensor. Im not sure why but I cannot get the car to stay running, it will start with some help with the throttle pedal and i can rev it up a bit but it always goes into reduced power and dies. I have increased the ETC table by a bunch and have tried to adjust the VE table both ways. The car ran fine with the 1bar sensor and just rescaling the injectors, it was drivable. ever since going 2bar and the COS i cannot get it to run.
Other comments (not related)
Also, these are out-of-range: A0001, A0002, A0012, A0013.
Fixing Out Of Range Cells:
showpost.php?p=87052 post #14
showthread.php?14119-3000-RPM-max-and-setting-codes-03-Z06-with-Magnuson-at-150kPa posts #14, #17
showthread.php?14654-I-need-help-getting-the-most-out-of-my-car post#2
Also, the 105kPa columns of both VE tables should be identical.
