Hey guys,
On my E38, B2517 which is TCS throttle limiter by input speed. It looks like the table is RPM x Gear, however the input values are marked as Nm? Bit confused....
Attachment 22222
Hey guys,
Attachment 22222
Thats right, it limits at the torque number via throttle limiting in the respective gear at the particular RPM.
Traction control when you dont have traction control ;)
So the table name "TCS Throttle Limiter by Input Speed" is a bit misleading then. That is where my confusion was, because I wasn't sure if I was putting in torque Nm values or speed KPH values. Cool!
Input speed is RPM........
