You can change VIN using V7 scantool.
Reading PCM flash does not require an ECM license.
JoeCar - thanks for the reply. You just saved me $125.
I am brand new to EFILive and this task will be my 1st attempt at using it.
I am considering attempting to build a bench cable for LMM ECM but I cannot find how to match the serial RS232 pins up to the PCM just yet. The link i found In this forum is broken and gives a 404 not found.
Thanks again.
Follow up. I found the pin out diagrams.
URL: http://download.efilive.com/Tutorial...0Tutorial.pdfI
Thanks.
