Well I guess just verify with that the OP said, DVT's not working at all.
I tested out the close/open loop fuel control on the e83b and it worked fine. that was all I tried at the time.
oh, I also reset the fuel trims too, i'll test out some other stuff too and let you know.
Closed/open fuel loop works.
Also the idle speed works as well but it has a tendency to time out if some other command is not accepted.
A number of the override functions in the ECM have a time limit (imposed by the ECM).
