Yet Another EGR thread.......
My understanding is the EGR system's purpose is to reduce NOx emissions, also the SCR's purpose is to reduce NOx emissions.
My question is:
Is it possible to disable the EGR, and its related codes, checks, etc., And use the SCR to compensate for the change?
I have already replaced the entire exhaust system from a larger engine series, I'm running the entire system from an LML on the LWN engine.
It works great and I have roughly 950-1300 miles in between regen cycles. No check engine light and have passed emissions tests multiple times.
I have no tune and no ECU modifications. I just ordered a FlashScan V3, In my area emissions are done, however, a pass/fail is based on actual tailpipe emissions. (No Emissions related codes present)
With the larger exhaust, I have a lot of ammonia slip, and I think it will be fine, I just don't know if this idea is possible with the controls of EFIlive.
My Truck:
2019 Colorado ZR2, 2.8L LWN engine
Complete exhaust from Silverado HD (LML), Sensors moved from Stock exhaust, using DEF injector from Silverado.
