I've got them now. Thanks for the cals cougar, but they were the same I had. I found 7.5.4 and now I have it.
the ecm torque limited injection quantity tables are only for defuel when the tcm request it. if you never touch the tcm and do lots of logging and run your logs against the tune tables, with the right changes you all but eliminate the defuel effect. thats how it was done long before the tcm tables came out in the beta release. now that the we have the ability to turn off the torque control there is no need to tune the torque tables in the ecm tune. the same table is in the tcm tune if you so choose to have the defuel left on. then you can change the defuel "effect" by adjusting the values in the 5196 table.
