Can someone tell me how to load my efi tunes and use my insight as the switch, it does not say in the edge directions and I called them and they said they can't help me. Step by step would be great since I'm pretty green with efi.
Thanks guys
Thanks guys
I take it you have EFILive?
Ya I assume that I have to convert it to dsp5 then serial data and load the tunes like I would if I was useing my v2 to change power levels I read how to do all that in the efi program I have my stock tune modified I just don't understand hot to add my other tunes and which script to pick to fill in the empty data
This is the tutorial you should follow, it explains it all.
You need to have it set to Serial Data for the Edge to work.
In the efilive explorer I don't have config in V8?
I also need to know how to change the swithing capability of going from the edge monitor as the switch to a dsp 5 switch? Can anyone tell me how to do this or point me in the right direction! Thanks!
Look at A0146
