36lb or stock LS1 injectors? HC is high...
Hi guys;
I've installed 36lb Bosch injectors to my car, and on the emissions it is horrible.
The HC level is around 2000ppm!
I have a cam (223/227@114 LC 0.592” lift use a valve spring with a lift of 0.600’) and full headers + high flow cat and no catalyzer.
I've used the ASA 2000/2002 corvette injector sizings and also tried some other resources, and even tried a stock tune with idle parameters, and cannot seem to get around it.
Is it really big for an LS1 5.7 with above additions to it?
should I use the stock injector sizing? would the stock duty cycle will be high or not?
any inputs are appreciated...
Evren
