Originally Posted by PCM History
Jun 24, 2005 19:04:19
Engine Calibration.Fuel.DFCO
{B3313} DFCO Temp Enable, changed from "-22.000000" to "250.000000".
Engine Calibration.Fuel.Mixture
{B3618} PE Modifier Based on RPM, modified.
{B3605} EQ Ratio When in Open Loop, modified.
Engine Calibration.Fuel.Trim
{B3801} Long Term Fuel Trim Correction, changed from "Enable" to "Disable".
{B4205} Closed Loop Temp Enable, modified.
Engine Calibration.Spark.General
{B5914} Spark Low-Octane Table, modified.
Engine Calibration.Cat Converter
{B0701} Catalytic Converter Protection Enable, changed from "Enable" to "Disable".
Engine Diagnostics
{C6002} Engine DTC MIL Enablers, modified.
Engine Diagnostics.MAF
{C2901} MAF High Frequency Fail 1, changed from "13500.000000" to "0.000000".
__________________________________________________ ______________________________
