TCC Locking up in 2nd - Programming says it shouldn't!
I've changed the TCC functions in 3rd and 4th gear but have made no changes to 2nd gear. (the tables still read stock @ 256). Went and made some wot runs and it felt like the car was just straining early on. Logged some data and can't figure out what I found! On a wot run, everything was fine except as soon as the PCM commanded 2nd gear, it also commanded TCC enable. It then stayed enabled until the command was given for 3rd gear. What the heck! Did some regular street logging and found that TCC enable is commanded during 2nd gear all the time (3rd and 4th are working as normal) I even tried to command TCC to off in bi-directional controls - went and did a wot and got the same results?!
Why is this?? Any chance that there is a glitch and changing my 3rd gear tables somehow corrupted something? My setup info is below.
Mark
402 Iron Block 1999 F body
Built 4L60E with vacuum modulator
3400 stall converter
