Does the 411 ECM care whether it's a Corvette or a truck TAC?
I posted the below quote in the Gen III forum, and realized that it might be better put in this forum. I've tried to clarify the question.
Quote:
Originally Posted by
Jim
I have read that when using Electronic Throttle Control, I should use compatible ECM (I'll be using a 411), TAC, Throttle Body, and pedal assemblies. If I use a 2002 Camaro tune and modify {G1207} Vehicle Platform Options to enable Electronic Throttle, does it work? If so, should I look for a truck or Corvette TAC and pedal?
This is an old post, but still a question for me. I see the switch to turn on electronic throttle in the F-body column {G1207} of my 12212156 OS. Is that compatible with both the Corvette and the truck TAC?
I've been trying to do my homework, but the best I have gleaned so far is that I must use compatible TACs and throttle pedals, so I can go with either a truck or a Corvette setup. I really don't want to pay the Corvette tax if I can help it, and I have read that some people have modified truck pedals to fit in tight spaces. I have a tight space situation.
I intend to use a 90mm throttle body (12570790), and the feeling I get is that it will work with either TAC. I'm basing my setup on a Camaro OS because I will be using a Camaro dash cluster.
My setup will be:
Gen 1 SBC
LS1 sensors
24x CKP, 1X CMP
12200411 ECM
FAST single-plane intake
I'm building a test bench to sort the ECM setup out before it gets installed on the engine. As this is my first project, I anticipate a lot of bench time figuring out what it will take to keep the ECM happy.
I have a lot of milestones ahead of me.
