LC-1 serial to FlashScan software?
OK, I searched and prodded and looked, but for some reason it's not obvious to me. How do I get the serial LC-1 to display in FlashScan software in real time?
I can display and record it to the SD card just fine, but I can't get it to work in pass-through mode for anything. I saw remarks in other threads that it was working in the latest release of the software, but I can't get it to enable any of the PIDs for the WB02 inputs.
None of these are enabled or are any of the calculated PIDs related to them.
EXT.W02AFR1
EXT.W02LAM1
EXT.W02ST1
In the V2 I have Everything turned on correctly:
COM In : Wide-02
COM Out : Wide-02
W02 Type: Innovate
Firmware: 2.05.17 May 03, 2008
BootBlock:2.05.08 Apr 25, 2008
EFILive_Scan.exe V7.5.4(Build 50)
Please tell me I'm a version behind or something..
On a side note I still get a lag trying to do the second record session on the V2, but I have done multiple 60 minute logs with no problems.
