No , not yet , going to get my MS Office CD back from neighbor and do the Spreadsheet with it and compare before putting into tune file .
Will post BEN data in the next few days .
Man the Spreadsheet is pretty awesome , SMOOTH !
Your screen shots are making me miss Vista. I am back on XP after having to give my old work laptop back :sad:
6 more days till public release and Office 2007 YAYA
Anyway, I digress.
FYI , just for the record OO Calc does work as MSO , pasted the same values into MSO and the Interpolated values are the same .
Did some tinkering and used the "smooth" feature in Flash Tool and came up with the exact same VE values as the Interpolated one .
So one can use the Smoothing feature in the Flash Tool and come up with the same Values .
Just an observation , Spreadsheet works but so does Smoothing in Flash Tool. :Eyecrazy:
The smoothing in the Tune Tool does work very well, I always start with a smoothed table. You can find though that that certain points of the table get increased/decreased more than is desirable, unless you are smoothing individual areas basically by hand...
I , see .Quote:
Originally Posted by Tordne
The Spreadsheet is much easier , I was just playing around and tried the Flash Tool smoothing and was amazed it did just as well and true I did do some of it in sections to achieve the same results .
